[GRASS5] [bug #825] (grass) r.poly doesn't write label points correctly
Glynn Clements glynn.clements at virgin.net
Sat Nov 10 09:53:50 EST 2001
Request Tracker wrote:
> When converting the dig_att/testpat to a sites list, the
> label positions are quite strange.
> I would expect the centers of the pattern.
It uses the horizontal midpoint of the widest part of the polygon:
  write_att(lab_digit, (char) dig_new_to_old_type(type),
      cell_head.west + (p->col + (p->width / 2.0)) * cell_head.ew_res,
      cell_head.north - (p->row + 0.5) * cell_head.ns_res,
      cat);
At first glance, the obvious change would seem to be to change:
to:
      cell_head.north - (p->row + (p->height / 2.0)) * cell_head.ns_res,
However, "struct area_table" doesn't have a height field. That would
need to be added (to extr_areas.h), and bounds.c would need to be
updated to record the height as well as the width.
"cvs log" suggests that all of the recent non-trivial changes have
been done by Andrea Aime, so he would be the obvious "volunteer" ;)
Glynn Clements <glynn.clements at virgin.net>
