[GRASS5] [bug #837] (grass) g.remove
Request Tracker grass-bugs at intevation.de
Fri Nov 16 10:32:26 EST 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=837
it keeps telling me to remove a file that doesn't exist....
$ g.list type=rast mapset=jidanni
raster files available in mapset jidanni:
pipeline
0grass$ g.list type=rast mapset=jidanni |egrep -v :\|-|xargs -n 1 g.remove
[pipeline at jidanni] is base map. Remove reclassed map first:
 pipeline3 at jidanni
0grass$ g.remove pipeline3
REMOVE [pipeline3]
 raster   MISSING
 header   MISSING
 category MISSING
 color    MISSING
 history  MISSING
 misc     MISSING
 fcell    MISSING
 g3dcell  MISSING
0grass$ g.remove pipeline3 at jidanni
REMOVE [pipeline3 at jidanni]
 raster   MISSING
 header   MISSING
 category MISSING
 color    MISSING
 history  MISSING
 misc     MISSING
 fcell    MISSING
 g3dcell  MISSING
0grass$ find $LOCATION|grep pipe
/home/jidanni/tmp/grass/../grassdata/leics/jidanni/cell/pipeline
/home/jidanni/tmp/grass/../grassdata/leics/jidanni/cell_misc/pipeline
/home/jidanni/tmp/grass/../grassdata/leics/jidanni/cell_misc/pipeline/null
/home/jidanni/tmp/grass/../grassdata/leics/jidanni/cell_misc/pipeline/range
/home/jidanni/tmp/grass/../grassdata/leics/jidanni/cell_misc/pipeline/reclassed_to
/home/jidanni/tmp/grass/../grassdata/leics/jidanni/hist/pipeline
/home/jidanni/tmp/grass/../grassdata/leics/jidanni/cellhd/pipeline
/home/jidanni/tmp/grass/../grassdata/leics/jidanni/cats/pipeline
oh, I can remove it manually from g.remove:
enter raster file to be removed
Enter 'list' for a list of existing raster files
Hit RETURN to cancel request
> pipeline
<pipeline>
Ok to remove [pipeline]? (y/n) y
REMOVE [pipeline]
 raster
 header
 category
 color    MISSING
 history
 misc
 fcell    MISSING
 g3dcell  MISSING
by the way, too bad there is no g.list "all" to see everything at once.
--- Headers Follow ---
>From neteler at itc.it  Fri Nov 16 16:32:26 2001
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
	by lists.intevation.de (Postfix) with ESMTP id D7D90139CC
	for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:32:24 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
	by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFWOf23380
Received: from artemide.itc.it (artemide [10.0.10.10])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFWNd19160
	for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:32:23 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
	by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFWME18142
	for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:32:22 +0100 (MET)
Received: (from neteler at localhost)
	by thuille.itc.it. (8.11.6/8.11.2) id fAGFWLd29540
	for grass-bugs at intevation.de; Fri, 16 Nov 2001 16:32:21 +0100
Resent-Message-Id: <200111161532.fAGFWLd29540 at thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
	by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMLE16724
	for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:21 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMHd18875
	for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:19 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
	id 714A016E1; Fri, 16 Nov 2001 23:02:29 +0800 (CST)
To: Markus Neteler <neteler at itc.it>
Subject: g.remove
Reply-To: jidanni at yahoo.com.tw
User-Agent: Gnus/5.0808 (Gnus v5.8.8) Emacs/20.7
Date: Fri, 16 Nov 2001 23:02:28 +0800 01:00:00 +0000 (GMT)
Message-ID: <m2wv0qzrln.fsf at Mdan.jacobson.tw>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Resent-From: neteler at itc.it
Resent-Date: Fri, 16 Nov 2001 16:32:21 +0100
Resent-To: grass-bugs at intevation.de
-------------------------------------------- Managed by Request Tracker
