[GRASS5] [bug #841] (grass) Re: r.reclass man
Request Tracker grass-bugs at intevation.de
Fri Nov 16 10:34:05 EST 2001
this bug's URL: http://intevation.de/rt/webrt?serial_num=841
I think there are stuff missing from this manpage
       1. This example reclassifies categories 1, 3 and 5 in
       the input     raster map layer to category 1 with category
       label
              and reclassifies input raster map layer  categories
              2,  4,  and  6  to  category 2 with the label "good
              quality" in the output map layer.
by the way, how does man find these without MANPATH?
--- Headers Follow ---
>From neteler at itc.it  Fri Nov 16 16:34:04 2001
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from omecihuatl.rz.uni-osnabrueck.de (omecihuatl.rz.Uni-Osnabrueck.DE [131.173.17.35])
	by lists.intevation.de (Postfix) with ESMTP id 982C1139CC
	for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:34:04 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
	by omecihuatl.rz.uni-osnabrueck.de (8.11.1/8.11.1) with ESMTP id fAGFY4f23500
Received: from artemide.itc.it (artemide [10.0.10.10])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFY2d19196
	for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:34:02 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
	by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFY1E18234
	for <grass-bugs at intevation.de>; Fri, 16 Nov 2001 16:34:01 +0100 (MET)
Received: (from neteler at localhost)
	by thuille.itc.it. (8.11.6/8.11.2) id fAGFY0F29560
	for grass-bugs at intevation.de; Fri, 16 Nov 2001 16:34:00 +0100
Resent-Message-Id: <200111161534.fAGFY0F29560 at thuille.itc.it.>
Received: from camelot.itc.it (camelot [195.223.171.5])
	by artemide.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMNE16735
	for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:25 +0100 (MET)
Received: from localhost.localdomain (h137.s30.ts32.hinet.net [163.32.30.137])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id fAGFMHd18876
	for <neteler at itc.it>; Fri, 16 Nov 2001 16:22:19 +0100 (MET)
Received: by localhost.localdomain (Postfix, from userid 501)
	id 3A87E16D2; Fri, 16 Nov 2001 15:18:47 +0800 (CST)
To: Markus Neteler <neteler at itc.it>
Subject: Re: r.reclass man
Reply-To: jidanni at yahoo.com.tw
In-Reply-To: <20011015171336.X29694 at itc.it>
User-Agent: Gnus/5.0808 (Gnus v5.8.8) Emacs/20.7
Date: Fri, 16 Nov 2001 15:18:44 +0800 01:00:00 +0000 (GMT)
Message-ID: <m2herv420b.fsf_-_ at Mdan.jacobson.tw>
MIME-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Resent-From: neteler at itc.it
Resent-Date: Fri, 16 Nov 2001 16:34:00 +0100
Resent-To: grass-bugs at intevation.de
-------------------------------------------- Managed by Request Tracker
