[GRASS5] [bug #837] (grass) g.remove
Glynn Clements glynn.clements at virgin.net
Thu Nov 29 23:56:00 EST 2001
guest user via RT wrote:
> Hi again on the g.remove/mapset bug.
> I can confirm that it exists:
> RASS:~ > g.list rast
> raster files available in mapset user1:
> archheights  fields.areas   file2    streams.thin  v1        vegcover.clump
> archrast     fields.areas1  mysoils  test          v1.clump
> raster files available in mapset PERMANENT:
> aspect          landuse       rushmore       soils.Tfactor   trn.sites
> density         owner         slope          spot.image      uparea
> elevation.dem   quads         soil.br.depth  streams         vegcover
> elevation.dted  railroads     soils          strm.dist
> erode.index     residential   soils.Kfactor  texture
> fields          roads         soils.ph       tractids
> geology         rstrct.areas  soils.range    transport.misc
> GRASS:~ > g.remove vegcover.clump
> [vegcover.clump at user1] is a base map. Remove reclassed map first:
>  vegcover.1000 at user1
> Looks like a bug to me,
Looks like user error to me. See my previous message on the subject.
Glynn Clements <glynn.clements at virgin.net>
