[GRASS5] Unix Sockets directory change...
Markus Neteler neteler at itc.it
Tue Oct 9 03:33:31 EDT 2001
On Tue, Oct 09, 2001 at 09:23:47AM +0200, Markus Neteler wrote:
> On Mon, Oct 08, 2001 at 04:24:08PM -0700, Eric G. Miller wrote:
> > I modified the unix socket routines to always use /tmp/grass-$USER/
> > as the directory.  This should overcome some problems with NFS
> > mounts.  Hopefully this works okay for everyone.
> Thanks, Eric!
> It's working properly here.
> For the others: To test, run
>   cvs up src/libes/gis
>   gmake5 src/libes/gis
>   gmake5 -i src/display/devices/XDRIVER
>   gmake5 -i src/display/d.mon
>   d.mon x0
> Check if /tmp/grass-$USER/ is present, containing the sockets file.
Sorry, not to forget: You have to recompile all d.* modules
and other monitor related modules!
Markus
