[GRASS5] PROJ_INFO and pj_get_kv() and r.in.gdal
Thu Oct 11 11:02:45 EDT 2001
Markus Neteler wrote:
> Here a gdb output:
> Program received signal SIGSEGV, Segmentation fault.
> 0x08053786 in G_find_key_value (key=0x8094c85 "meters", kv=0x0)
>     at key_value1.c:106
> 106         for (n = 0; n < kv->nitems; n++)
> key_value1.c is in /src/libes/gis I think.
> Shall I test more with gdb?
Markus,
The code is fundamentally flawed (proj_info is  usually uninitialized).
I will restructure this morning.
Later,
