[GRASS5] Re: xganim compilation
Markus Neteler neteler at itc.it
Fri Oct 19 11:07:13 EDT 2001
On Fri, Oct 19, 2001 at 02:11:18PM +0100, Glynn Clements wrote:
> Helena wrote:
> > > Unfortunately the program is restricted to 8bit:
> > > xganim soils,nations
> > > VIEW 1: soils nations
> > > Can't get required 8-bit visual.
> > > Would it be a big task to allow it to run on 24bit (or any) visual?
> > > I guess, this will be Helena's next question :-)
> I've committed a version which should support any visual.
> Glynn Clements <glynn.clements at virgin.net>
Glynn,
thanks a lot! It is working well. From the diffs I can see
that this was plenty of work.
Best regards
 Markus
