[GRASS5] pre2 nviz & darwin -- part ii
andy agena andya at mac.com
Thu Oct 25 13:46:38 EDT 2001
hi again:
jeshua zapped me libdl.a and libdl.dylib, so i have them installed now.
however, if i try nviz from tcltkgrass, the command passed is "nviz
el=elevation.dem", which gives "Sorry, <el=> is ambiguous".
if i try from the cli, i get :  "ERROR: window name "wait_ok" already
exists in parent..."
any ideas?
thanks,
andy
On Thursday, October 25, 2001, at 10:29 AM, Glynn Clements wrote:
> andy agena wrote:
>> i have grass5pre2 running on darwin1.4 (osx 10.1) and received the
>> following error when trying to launch nviz.  most of my *.dylib are in
>> /usr/lib; i only have a few tcltk *.dylib's in /usr/local/lib.
>> GRASS 5.0.0pre2 > nviz
>> dyld: /usr/local/grass5/etc/nviz2.2/NVWISH2.2 can't open library:
>> /usr/local/lib/libdl.dylib  (No such file or directory, errno = 2)
> Odd. Is libdl.dylib present on your system, in /usr/lib,
> /usr/local/lib or elsewhere?
> FWIW, try removing $(DLLIB) from src.contrib/GMSL/NVIZ2.2/src/Gmakefile;
> if Tcl needs libdl, configure will add -ldl to TCLTKLIBS.
> Glynn Clements <glynn.clements at virgin.net>
