[GRASS5] pre2 nviz & darwin -- part ii
andy agena andya at mac.com
Fri Oct 26 01:59:26 EDT 2001
On Thursday, October 25, 2001, at 07:08 PM, Glynn Clements wrote:
> andy agena wrote:
>> however, if i try nviz from tcltkgrass, the command passed is "nviz
>> el=elevation.dem", which gives "Sorry, <el=> is ambiguous".
> Odd; that works fine here, both from the command line and via
> tcltkgrass.
> What does "nviz help" say?
GRASS 5.0.0pre2 > nviz help
Description:
  nviz - Visualization and animation tool for GRASS data
Usage:
  nviz2.2_script [-qkx] [elevation=name[,name,...]]
    [vector=name[,name,...]] [sites=name[,name,...]] [path=name]
    [script=name]
Flags:
   -q   Quickstart - Do not load any data
   -k   Script kill option
   -x   Start in Demo mode
Parameters:
   elevation   Raster file(s) for Elevation
      vector   Vector overlay file(s)
       sites   Sites overlay file(s)
        path   Set alternative panel path
      script   Execute script file at startup
        Mapset <PERMANENT> in Location <spearfish>
> Glynn Clements <glynn.clements at virgin.net>
