[GRASS5] pre2 nviz & darwin -- part ii
Bob Covill bcovill at tekmap.ns.ca
Fri Oct 26 13:39:14 EDT 2001
Glynn Clements wrote:
> andy agena wrote:
> > >> however, if i try nviz from tcltkgrass, the command passed is "nviz
> > >> el=elevation.dem", which gives "Sorry, <el=> is ambiguous".
> > > Odd; that works fine here, both from the command line and via
> > > tcltkgrass.
> > > What does "nviz help" say?
> > GRASS 5.0.0pre2 > nviz help
> [snip]
> That implies that the error message is bogus, i.e. a problem with
> G_parser(), but I can't see anything obvious.
> Glynn Clements <glynn.clements at virgin.net>
I am guessing here, but is it possible that TCL (tcltkgrass) is getting
confused with the command? In other words is it reporting the error
before it even gets to G_parser?
It might help to know what the raster file name is that is creating the
problem in case of odd characters. Or is it "elevation.dem".
Bob Covill
Tekmap Consulting
E-Mail: bcovill at tekmap.ns.ca
