[GRASS5] pre2 nviz & darwin -- part ii
Glynn Clements glynn.clements at virgin.net
Tue Oct 30 15:29:15 EST 2001
Jeshua Lacock wrote:
> > What happens if you copy NVWISH2.2 to some other directory, then run
> > it from there?
> Hi Glynn,
> After I moved NVWISH to it's parent directory, fired up Grass, and I
> typed nviz. It reported that NVWISH2.2 could not be found.
> So changed to the directory where I moved it (etc/), ran NVWISH2.2 and I
> was prompted for a elevation file so I typed in topo (leics). I then
> choose defaults for the rest of the prompts and a NVWISH2.2 window
> appears and the command line freezes at "translating colors 99%".
> If there is anything else you would like for me to try, please let me
> know.
What I meant was to move NVWISH2.2 to some completely unrelated
directory, then run NVWISH2.2 directly (rather than the "nviz"
script).
I'm trying to check whether the suspicion which I outlined in the the
previous message is correct, i.e. that Tk is using the executable's
pathname to guess the location of its library directory (for tk.tcl
etc).
E.g. run:
	mkdir $HOME/foo/bar/baz
	cp /usr/local/grass5/etc/nviz2.2/NVWISH2.2 $HOME/foo/bar/baz
	$HOME/foo/bar/baz/NVWISH2.2
and see which directories are listed in the resulting error message.
Glynn Clements <glynn.clements at virgin.net>
