[GRASS5] s.to.rast question
Michel Wurtz mw at teledetection.fr
Thu Sep 13 15:18:19 EDT 2001
Kevin Slover wrote:
> Does the s.to.rast write a temporary file somewhere to check on the
> progress??  I am working with a large file and am wondering if it is still
> running properly or not.  I let it run overnight last night, and came into
> find it still running, and started again this morning about 0900 and it
> continues to run at this time (1110).
Yes, it writes a temp file, and after that copy it to the real raster file.
since it uses G_tempname(), you should find it at the habitual location.
Michel WURTZ - DIG - Maison de la télédétection
               500, rue J.F. Breton
               34093 MONTPELLIER Cedex 5
