[GRASS5] site time stamp
Helena hmitaso at unity.ncsu.edu
Fri Sep 28 08:42:29 EDT 2001
Markus,
your are right, I had it all wrong .
As far as I know, there is no document readily available on the site
format (supposedly it is in the programmers manual, but that is not easily
accessible
unless you know it). I will prepare a html document with the description of
ascii formats
and it should be put at
http://grass.itc.it/gdp/html_grass5/index.html
into reference manual section (and fix it in chapter 7).
I will ask others to review it to make sure that it is right.
thanks a lot ,
Helena
> Helena,
> On Thu, Sep 27, 2001 at 08:03:55PM -0500, Helena wrote:
> > I am testing the support for spatio-temporal data and I have found that
> > the time stamp in the site file header is ignored by s.surf.rst and s.info
> > - I checked the code and I don't see a bug there so it appears that the
> > problem is in G_site_get_head or I am not using the right format. I could
> > not find a description of the site format and its header on the official
> > GRASS website so I am using my notes which may be obsolete (Markus I know
> > that it is in the prog. manual but I cannot read it at the moment).
> > According to that, header with time stamp looks like this:
> > name|test.time
> > desc|Testing time stamp survey data from NRCS for Ft.Hood subwatershed
> > timestamp|15 Jan 1998
> It seems that G_site_get_head() is looking for "time", not "timestamp".
> (src/libes/gis/sites.c)
> That's it. Where shall this be documented?
> s.info test
> NDIM=2, RTYPE = 0, NSTR=0, NDEC=1
> Total sites read: 30
> Total sites outside region: 0
> test read.
> SITES FILENAME: test
> Header Information:
>         name          d010619.site
>         labels        east north no1 no2
>         time          19 Jun 2001
> Number of DIMENSIONS:         2
> Cheers
>  Markus
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
