[GRASS5] raster file history question
Markus Neteler neteler at itc.it
Thu Apr 4 12:53:36 EST 2002
Just a followup:
Did anyone ever try
 src/scripts/contrib/metadata
r.meta
v.meta
Markus
On Thu, Apr 04, 2002 at 01:52:57PM -0500, Helena Mitasova wrote:
> In the US many government agencies must include a standard and very detailed
> metadata file with the data that they distribute. It would be extremely useful
> if this file was imported
> along with the data and either stored in the description part of history file
> (r.info might need modification then)
> or as a separate file, along with history file. As far as I know there is free
> code supporting
> the management of this file, in case that something more than just copying the
> file to the GRASS
> database would be considered.
> Frank do you use or consider this file in GDAL?
> Helena
> Markus Neteler wrote:
> > On Thu, Apr 04, 2002 at 03:49:08PM +0200, Andreas Lange wrote:
> > > Hi,
> > > > Ok, sorry for boing unclear. A new try:
> > > > I want to store the command line, which was used to start a
> > > > module, into the history section of data.
> > > > Example: I run
> > > > r.proj dgm1km loc=europa map=europa
> > > > When I now run
> > > >  r.info dgm1km
> > > > the string "r.proj dgm1km loc=europa map=europa" should appear in
> > > > the history. This is implemented in r.slope.aspect and s.surf.rst,
> > > > but more complicated there. For my module (not r.proj) the command line
> > > > string is sufficient to later remember the parameters which I used to
> > > > generate that particular map.
> > > > It must be something with argv[] or so.
> > > what about G_recreate_command()? IMHO this gives a complete command
> > > line, even if the command was invoked interactively.
> > yes - this will be the command I was looking for. Thanks for the pointer.
> > > I think that a own library for accessing and creating metadata (history
> > > data) would be very useful. Somehow the metadata capabilites should be
> > > unified for all modules (raster, vector, sites).
> > Oh yes - that's really needed! On FreeGIS mailing list is currently some
> > discussion about that, see
> >  http://intevation.de/pipermail/freegis-list/
> > However, even a simple solution might be better than what's currently
> > implemented. At least the data import modules should take more care about
> > that (eventually optionally ask the user about data source, year etc).
> > Markus
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
> grass5 mailing list
