Fwd: Re: [GRASS5] line types
Roger Miller rgrmill at rt66.com
Mon Apr 8 20:27:50 EDT 2002
On Monday 08 April 2002 18:15, Eric replied:
> > In both cases it is sufficient to change the code to perform the
> > operation regardless of whether the line is typed as an area edge or as
> > a line.
> I'm not sure if this is acceptable behavior for most people.  How do you
> distinguish the case where people only want the labelled LINE types as
> line, and not area boundaries?  The handling in GRASS hasn't been too
> good for mixing types in one map (even though it is allowed).
An alternative would be to fix all the modules so that they actually work on
either line type.  In the case of the two modules I was talking about that
means modifying v.llabel to label lines that are typed as either lines or
area edges and modifying v.extract so that it can extract "area edge" lines
based on the category of the line, not on the category number of the enclosed
area.
At this time GRASS offers no control of line types that are practical on
realistically-sized vector maps.  Besides, the limitation in v.out.shape
required that everything form closed areas, so being able to alter a line
type in v.digit was of no value anyway.
As a result of the lack of practical control there are probably few users who
care about the distinction.
I can blather on and on about the practical problems caused by the
distinction between lines and area edges.  What i've talked about so far only
scratches the surface.  As it is I see no value in making the distinction and
a lot of problems caused by it.  The simplest solution would probably be to
treat every line as a (potential) area edge.
> Your right that it shouldn't matter to users.  All that should matter
> is, does an edge participate as an area boundary?  Does the edge
> participate in a line feature?  Unfortunately, it doesn't change any
> of the architechtural shortcomings of < 5.1 vectors.
How can we expect to fix the modules in the more complex setting of 5.1 if we
don't first get a handle on the problems caused by the relatively simple
setup in 5.0?
Roger Miller
