[GRASS5] datum shifts
Bernhard Reiter
bernhard at intevation.de
Fri Apr 19 16:29:01 EDT 2002
On Fri, Apr 19, 2002 at 02:15:05PM -0700, rgrmill at rt66.com wrote:
> > Shouldn't this be done at GRASS compile time, so to have the
> > right binary tables for the platform?
> > Or will the format change with proj library versions
> > that have the same binary interface?
> Yes, it does need to be done when GRASS is compiled.
We need a Makefile entry for this.
Maybe Glynn can help if you give him the commands?
> > > I think the data tables
> > > have to go under $GISBASE somewhere.
> > That is not hardcoded, though...
> > It providing an option to specify a non-default path a good idea?
> That part that has to be hard coded is the part after $GISBASE, probably
> "/etc/nad/". No more than I know now, it looks easier for me to code
> this if there is no user option.
Usually I do not call a fixed relative path hardcoded... :)
> > > Wherever they do go has to be
> > > coded into the proj library.
> > This confuses me a bit, is it an addition to proj then?
> I guess I could be more specific. A program that uses the nad<->nad
> conversion in the proj library has to call a function called "nad_init".
> "nad_init" takes one argument, and that is the fully qualified file name
> for the data table that it will use for the conversions. "nad_init" is
> part of the proj distribution.
Okay, thus you have to specify it when initialising proj.
No need to "code" it into library itself.
> It looks now like the name should be
> 'getenv("GISBASE")/etc/nad/<table name>'.
Sounds reasonable to me.
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020419/936ddc7b/attachment.bin
