[GRASS5] g51 Vect_set/get_header
Radim Blazek blazek at itc.it
Mon Apr 29 12:02:05 EDT 2002
in g51 vector library, i would like to replace direct access to
Map_info structure and replace fuctions like V2_num_lines()
by one or few funcitons. I see two possibilities:
1.
int Vect_get_header( struct Map_info Map, int item, char *cval,
              int *ival, double *dval)
    - *val would be pointers to variables where the value should be saved
2.
char Vect_get_header_c( struct Map_info Map, int item)
int   Vect_get_header_i( struct Map_info Map, int item)
double Vect_get_header_d( struct Map_info Map, int item)
     - all return value (pointer to value)
item is code for header field (GV_HEAD_SCALE, GV_NUM_LINES, ...)
What should i use? Or do you know about anything better?
Radim
