[GRASS5] Script to build babyGRASS for handhelds
Markus Neteler neteler at itc.it
Mon Apr 29 13:33:52 EDT 2002
On Mon, Apr 29, 2002 at 05:27:24PM +0000, Carl Worth wrote:
> On Apr 29, Markus Neteler wrote:
>  > Thanks for the hint - the size is shrinked by around 50% to
>  > 1.7MB.
> Excellent.
Yes - the command included are:
- db.* modules
- g.gisenv
- d.mon
- d.rast
- d.vect
- d.sites
- d.erase
- d.what.rast
- d.what.vect
- d.what.sites
- d.measure
- d.pan
- d.zoom
- g.region/cmd
- manage (g.list, g.remove etc)
- r.in.ascii
- s.in.ascii
Of course the script can be easily extended.
>  > If anyone else is interested, I have another script now to
>  > extract babyGRASS from a common code directory into a new
>  > tarball. Also the compile script is improved. Let me know,
>  > then I send it to you.
> Markus, I'd be interested in this. Perhaps you could commit it into
> CVS somewhere.
OK - do you have a suggestion for a place?
Maybe in
tools/
>  > Currently we cannot login into the Skiff cluster (down), otherwise
>  > inital GRASS/iPAQ binaries would probably already available.
> Other options are to compile GRASS natively on an iPAQ or using a
> cross-compiler, (which I have done successfully for very large portions
> of GRASS). I have both options readily available here, so I can
> compile up this lightweight GRASS distribution and contribute it to
> the Familiar Linux distribution for easy installation on handhelds.
That we didn't try yet. Perhaps we should also add a
GRASS/Handhelds
web page to stimulate further interest.
Markus
