[GRASS5] Re: c++ question
Laura I. Toma laura at cs.duke.edu
Thu Aug 8 11:58:52 EDT 2002
r.in.gdal is a bit different from what I am doing. GDAL provides functions
which are heavily used by developers of other modules. I can see why you
want a C wrapper around it. I'm trying to write an 'independent' module
similar  with r.watershed, or r.flow. I don't expect to be used internally
in other  parts of GRASS. In any case, the function that computes flow is
actually  in C, so I could think of that as the wrapper.
The part that's in C++ is the I/O-efficient library, containing
implementation for I/O-efficient streams, I/O-efficient sorting,
I/O-efficient priority queue, lists and so on. If at some point we'll
want to make that a separate library usable by other modules, that will
have to be wrapped in C. But for now it is just inside my module.
thanks, I'm all set for now
-Laura
On Thu, 8 Aug 2002, Markus Neteler wrote:
> Helena, Laura
> (cc grass5)
> [Laura, the MailMan was catching your mail, only subscribers
> can post... sorry. This avoids spamming.]
> On Wed, Aug 07, 2002 at 07:36:47PM -0400, Helena wrote:
> > Markus,
> > you might have noticed Laura's question about the c++ code - originally
> > she wanted to implement her old c-code, but that one did not have lot
> > of capabilities that we needed so she is trying to do it with the newer
> > c++ version of terraflow. I told her to look at gdal code which is c++,
> > but I am not sure whether that would work for her. It would be good to
> > do this with the future structure of grass code in mind - do you have any
> > advice for this, or who would be a good person to contact?
> from the previous discussions about C++ there was some consensus not
> to introduce C++ intro GRASS directly. But: GDAL contains a C wrapper
> around the C++ functions which are needed for the interface (called
> "GDAL bridge").
> Laura, maybe you can wrap the interfacing functions of your code to C?
> The same we expect for OGR (the vector counterpart for GDAL raster),
> a C wrapper ("OGR bride" or so). Frank Warmerdam has developed the
> GDAL bridge. It's part of GDAL (subdirectory bridge):
> http://remotesensing.org/gdal/
> I am rather sure that core GRASS remains C, but such wrappers may
> establish the connection to C++.
> There is also the "libgrass" containing I/O routines of GRASS (the related
> C functions extracted for that package). I am using that for
> GRASS/MapServer.
> Maybe the other developers have a different opinion?!
> Markus
