[GRASS5] i.tm.dehaze problem
Markus Neteler neteler at itc.it
Mon Aug 12 10:48:09 EDT 2002
On Sat, Aug 10, 2002 at 07:21:14PM +0100, Gualter Barbas Baptista wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> I'm trying to run the i.tm.dehaze but I'm getting the errors below. Does
> anyone know what this means and how can be solved? I'm running
> 5.0.0pre3, could this be some old bug?
> GRASS:~ > i.tm.dehaze inverno.tasscap.4 b1 b2 b3 b4 b5 b7
> r.stats:  100%
> 1 variables
> 0 observations
> ERROR: SVDCMP: You must augment A with extra zero rows
this looks as a problem r.linear.regression. It is suspicious that
there are '0 observations'.
Are you sure that you work in a region with data (check with d.erase;d.rast)?
Note that i.tm.dehaze is a script without good error testing.
Markus
