[GRASS5] Re: [GRASSLIST:4315] Re: s.surf.rst output extent (wrap up)
Markus Neteler neteler at itc.it
Mon Aug 19 11:30:18 EDT 2002
On Mon, Aug 19, 2002 at 10:17:55AM -0400, Russell Nelson wrote:
> Markus Neteler writes:
>  > a cross-post from grasslist:
>  > Should we consider to force a chmod to write permission enabled for user
>  > in case a map is set to read-only (example see below)?
> What if it was *supposed* to be read-only?  Better to say why the file
> write failed.  "You own that file, but you don't have write permission
> for it.  Consider using chmod."
Sound's very good. Let's implement that in the libs.
 Markus
