[GRASS5] Objections to release 5.0.0stable?
Markus Neteler neteler at itc.it
Tue Aug 20 18:00:19 EDT 2002
Thanks for analysing that again.
Tomorrow I'll try to compile the release branch (and develop a
script for that according to release rules, should be easy).
Then we may publish the tarball somewhere for testing.
Markus
> > > > > are there any objections to release 5.0.0stable?
> > > > > I can't see release critical bugs.
> > > > > If no objections, we should tar the ball,
> > > > First, we should check whether any important fixes still need to be
> > > > merged into the release branch.
> > > Yes, certainly (I was silently including the somewhat common procedure,
> > > silently hoping for your assistance :-)
> > OK. I've analysed the diffs:
> Below is a list of the outstanding differences which, in the absence
> of arguments to the contrary, won't make it into the release.
> Glynn Clements <glynn.clements at virgin.net>
> NEWS.html
> 	Document fixes since pre5
> html/html/m.in.e00.html
> src/misc/m.in.e00/info.c
> src/misc/m.in.e00/main.c
> html/html/d.vect.pg.html
> locale/ru/LC_MESSAGES/d.vect.pg.po
> src.garden/grass.postgresql/d.vect.pg/dbvect.h
> src.garden/grass.postgresql/d.vect.pg/getAllOpts.c
> src.garden/grass.postgresql/d.vect.pg/getSopts.c
> src.garden/grass.postgresql/d.vect.pg/main.c
> src.garden/grass.postgresql/d.vect.pg/runInfxFile.c
> 	-e flag
> locale/ru/LC_MESSAGES/v.to.pg.po
> src.garden/grass.postgresql/v.to.pg/dbvect.h
> src.garden/grass.postgresql/v.to.pg/getAllOpts.c
> src.garden/grass.postgresql/v.to.pg/getSopts.c
> src.garden/grass.postgresql/v.to.pg/main.c
> src.garden/grass.postgresql/v.to.pg/plotCat.c
> src.garden/grass.postgresql/v.to.pg/runInfxFile.c
> 	-p flag (PostGIS)
> html/html/d.dm.html
> src/display/d.dm/d.dm
> 	add PNG feature
> + src/display/d.text.freetype/vflib
> + src/display/d.text.freetype/test.input
> html/html/d.text.freetype.html
> src/display/d.text.freetype/Gmakefile
> src/display/d.text.freetype/freetypecap
> src/display/d.text.freetype/main.c
> 	new options: align=, rotation=, -r, -p, -s, -c
> 	command mode
> src/display/d.vect/cmd/main.c
> src/display/d.vect/cmd/plot2.c
> src/display/d.vect/cmd/plotCat.c
> html/html/d.legend.html
> src/tcltkgrass/module/d.legend
> src/display/d.leg.thin/main.c
> src/scripts/contrib/d.rast.leg/d.rast.leg
> 	-o flag (only show used categories)
> 	maxfontsize= option
> 	fix d.rast.leg script (use g.gisenv to obtain GISDBASE/LOCATION_NAME/MAPSET)
> html/html/ps.map.html
> + src/ps.map/ps.map/cmd/ps_fclrtbl.c
> src/ps.map/ps.map/cmd/Gmakefile
> src/ps.map/ps.map/cmd/colortable.h
> src/ps.map/ps.map/cmd/ctablfile.c
> src/ps.map/ps.map/cmd/eps.c
> src/ps.map/ps.map/cmd/local_proto.h
> src/ps.map/ps.map/cmd/ps_area.c
> src/ps.map/ps.map/cmd/ps_map.c
> src/ps.map/ps.map/cmd/read_cfg.c
> src/ps.map/ps.map/cmd/vectfile.c
> src/ps.map/ps.map/cmd/vector.h
> 	Add height option to "colortable" command
> 	Add pat, pwidth, scale options to "vector" command
> 	Support FP colour tables.
> + html/html/r.to.pg.html
> src/scripts/contrib/r.to.pg/r.to.pg
> 	Add HTML file
> 	Support attribute cats
> src/tcltkgrass/todo/r.colortool/r.colortool
> 	Use g.gisenv to obtain GISDBASE/LOCATION_NAME/MAPSET
> locale/Gmakefile
> 	Add tcltkgrass textintro targets
> + locale/ru/grass_intro.txt
> + locale/ru/license.txt
> + src/general/init/license.txt
> src/general/init/Gmakefile
> src/general/init/init.sh
> 	Startup i18n
> + locale/ru/tcltkgrass
> src/tcltkgrass/main/gis_set.tcl
> src/tcltkgrass/tcltkgrass
> 	tcltkgrass i18n
> + locale/ru/LC_MESSAGES/libgis.po
> src/libes/gis/Gmakefile
> src/libes/gis/G_dump.c
> src/libes/gis/adj_cellhd.c
> src/libes/gis/ask.c
> src/libes/gis/ask_cell.c
> src/libes/gis/auto_mask.c
> src/libes/gis/cats.c
> src/libes/gis/closecell.c
> src/libes/gis/color_read.c
> src/libes/gis/datum.c
> src/libes/gis/done_msg.c
> src/libes/gis/env.c
> src/libes/gis/error.c
> src/libes/gis/format.c
> src/libes/gis/get_cellhd.c
> src/libes/gis/get_datum.c
> src/libes/gis/get_datum_name.c
> src/libes/gis/get_ell_name.c
> src/libes/gis/get_ellipse.c
> src/libes/gis/get_projinfo.c
> src/libes/gis/get_projname.c
> src/libes/gis/get_row.c
> src/libes/gis/get_window.c
> src/libes/gis/gishelp.c
> src/libes/gis/gisinit.c
> src/libes/gis/histogram.c
> src/libes/gis/history.c
> src/libes/gis/home.c
> src/libes/gis/legal_name.c
> src/libes/gis/list.c
> src/libes/gis/location.c
> src/libes/gis/make_colr.c
> src/libes/gis/mapset.c
> src/libes/gis/mapset_msc.c
> src/libes/gis/mask_info.c
> src/libes/gis/myname.c
> src/libes/gis/null_val.c
> src/libes/gis/opencell.c
> src/libes/gis/parser.c
> src/libes/gis/proj2.c
> src/libes/gis/proj3.c
> src/libes/gis/put_cellhd.c
> src/libes/gis/put_row.c
> src/libes/gis/put_title.c
> src/libes/gis/quant_io.c
> src/libes/gis/quant_rw.c
> src/libes/gis/range.c
> src/libes/gis/rd_cellhd.c
> src/libes/gis/readsites.c
> src/libes/gis/readsites_xyz.c
> src/libes/gis/reclass.c
> src/libes/gis/set_window.c
> src/libes/gis/sites.c
> src/libes/gis/system.c
> src/libes/gis/timestamp.c
> src/libes/gis/view.c
> 	libgis i18n
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
