[GRASS5] [bug #1238] (grass) r.transect_no_result
Markus Neteler neteler at itc.it
Thu Aug 22 12:16:14 EDT 2002
On Thu, Aug 22, 2002 at 05:15:25PM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1238
> Subject: r.transect_no_result
> Platform: GNU/Linux/i386
> grass obtained from: Trento Italy site
> grass binary for platform: Compiled from Sources
> GRASS Version: 5.0pre4
> Please enter error description here (and your name)
> I did not get any results with r.transect.
> Could you please change in source code main.c
> line 85 and 86 from:
> sprintf (command, "r.profile map='%s' width=%s result=%s
> line=",
> parms.map->answer, parms.width->answer,
> parms.result->answer);
> to updated command of r.profile for example:
>    sprintf (command, "r.profile input='%s' output=-
> profile=",
> 	parms.map->answer);
> Then it'll be fixed.
Thanks for the hint!
I think also profile= must be eliminated and also the
width parameter in r.transect (and the html file updated and
tcltkgrass for r.transect).
This should reach the release_branch, otherwise r.transect
is unusable.
 Markus
