[GRASS5] Bug status
Bernhard Reiter bernhard at intevation.de
Fri Aug 23 11:18:00 EDT 2002
Spend some time to screen issues in the bug-tracker today.
You might have seen some of the questions this created.
Here are the current stats
Bugs:
	|            54 | open     |
	|             3 | stalled  |
Andreas, Glynn: Can you recheck on that stalled bugs?
Priority of the open bugs:
	| count(priority) | priority |
	|               1 |       10 |
	|               6 |       20 |
	|               1 |       25 |
	|               1 |       28 |
	|              44 |       30 |
	|               1 |       70 |
This means: We need more people to classify the bugs,
which is a good indicator for the more active developers on what to
focus on first.
BTW: The high priority bug is #1052 [rsv].proj are crashing
which might already fixed. I've asked that by separate mail.
Wishs:
	|            32 | open     |
	Priorities:
	|               1 |       15 |
	|               3 |       20 |
	|              28 |       30 |
Same thing: We should prioritise the wishs at least a bit.
Here are the people with the most transactions in the grass queue
beginning with 2002 07 01 (I've simplified).
My current session catapulted me on top of the list
Thanks for Markus and Glynn for their continuing efforts
to improve grass which also can be seen in their activities in the
issue tracker.
To all others: Helping to classify, test bugs and wishes
on the bug tracker is a good possibility to help GRASS move
forwards. :)
| count(t.actor) | actor                     |
|             47 | guest                     |
|             44 | bernhard                  |
|             18 | mneteler                  |
|             15 | gclements                 |
|              2 | cheg01 at attbi.com          |
|              2 | Kevin.Slover at noaa.gov     |
|              2 | otto.dassau at gmx.de        |
|              1 | blazek at itc.it             |
|              1 | egm2 at jps.net              |
|              1 | mw at teledetection.fr       |
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020823/80121d65/attachment.bin
