[GRASS5] [bug #1228]
Glynn Clements glynn.clements at virgin.net
Fri Aug 23 19:37:09 EDT 2002
Bernhard Reiter wrote:
> > > I think the
> > > fix for src/libes/edit/edit_cellhd.c should be merged in before release
> > I've just committed a fix for [bug #1228] to that file. The release
> > branch version (1.1.2.1) is sync'd with head version 1.2. 1.3 is the
> > "void" fix, 1.4 is the latest fix.
> There seems to be a fix for bug 1228 in the CVS HEAD.
> This means it probably will be in the 5.0.0 or 5.0.1 release.
> Can we close the bug then?
That has since been merged into the release branch, so the bug can be
closed.
Glynn Clements <glynn.clements at virgin.net>
