[GRASS5] Re: [GRASSLIST:4357] merge of lines
Bernhard Reiter bernhard at intevation.de
Mon Aug 26 05:24:37 EDT 2002
Radim,
thanks for the answers.
On Mon, Aug 26, 2002 at 10:41:46AM +0200, Radim Blazek wrote:
> On Thursday 22 August 2002 03:49 pm, Silke Reimer wrote:
> > On Thu, Aug 22, 2002 at 01:17:22PM +0200, Markus Neteler wrote:
> > > On Thu, Aug 22, 2002 at 01:13:31PM +0200, Bernhard Reiter wrote:
> > > > It seems that there is not option in v.digit -> edit
> > > > to join two lines that share a node.
> > > > Is there a reason for this in the data model?
> No.
> > > > It should be fairly easy to do.
> You can do that (some check for different categories should be done).
> > Any suggestions? Or perhaps any reason why it isn't sensible to do
> > so?
> v.build.polylines
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020826/c5a7507b/attachment.bin
