[GRASS5] Grass 5.0 Pre3 Darwin Report
Jeshua Lacock jeshua at SierraMaps.com
Mon Feb 4 23:14:19 EST 2002
Hello all,
I have successfully built and tested Grass 5.0 pre 3, NVIZ, etc. on Mac
OS X (Darwin 5.1).
I just started uploading the binaries to grass.itc.it in the incoming
directory.
There is something new that was not happening with previous builds: When
I execute tcltkgrass I get the following message:
GRASS 5.0.0pre3 >  called create main window
  assigning interp 714928
  tsd is 756320 datakey 756320
  tsdptr 756320 datakey 756320
  start search mainPtr 798816
look for 714928 got 714928
This goes on and on for about a couple hundred more lines.
Is there a way to deactivate this "feature"? Is Pre 3 being generated
with debugging on or something? It does not seem to harm anything, just
a bit a of a nuisance.
BTW: This build is 122 MB again, I cannot seem to make it smaller, the
Pre 2 binaries are 50 MB...
Cheers,
Jeshua Lacock __________________________
Programmer/Owner            Phone:   760.935.4736
http://OpenOSX.com           Fax:        760.935.4845
-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_-_
