[GRASS5] CVS branch with latest 5.0 code?
Aleksey Y Naumov naumov at acsu.buffalo.edu
Tue Feb 5 00:13:38 EST 2002
Thanks, Glenn.
Aleksey
On Mon, 4 Feb 2002, Glynn Clements wrote:
> Aleksey Naumov wrote:
> > with all the CVS merging lately, I lost track somewhat -- which branch now
> > has the latest 5.0 code -- still "releasebranch_11_april_2001_5_0_0"? So, to
> > start fresh I'd do:
> > cvs co -r releasebranch_11_april_2001_5_0_0 grass
> > Right?
> The release branch should be almost identical to the head. If a file
> exists in both the release branch and the head, both versions should
> be identical. The head will also contain some files which don't exist
> in the release branch (e.g. d.vect.area and r.mapcalc3).
> > How do I check out GRASS 5.1 -- "cvs co grass5.1"?
> It's called "grass51".
> Glynn Clements <glynn.clements at virgin.net>
