[GRASS5] Using 'vask' library
Glynn Clements glynn.clements at virgin.net
Tue Feb 12 02:42:06 EST 2002
Markus Neteler wrote:
> I have changed the old passage:
[snip]
> to (new):
> \textbf{Note.} The target \textit{pgm} depends on the object files \$(OBJ)
> and the \textit{Vask Library} \$(VASKLIB). This is done so that
> modifications to any of the \$(OBJ) files or to the \$(VASKLIB) itself will
> force module reloading. Linking against the Vask library is \$(VASKLIB)
> \$(CURSES), it specifies both the UNIX curses and termcap/terminfo libraries
> as well as \$(VASKLIB).
> [sorry for the Latex markup]
> Does this change make sense? If not, please correct, then I publish the
> updated PDF.
The phrase "Linking against the Vask library is \$(VASKLIB) \$(CURSES)"
isn't grammatically correct. It should probably say something like
"Linking against the Vask library is performed using \$(VASKLIB) \$(CURSES)"
Apart from that, it's OK.
Glynn Clements <glynn.clements at virgin.net>
