[GRASS5] [bug #919] (grass) r.in.gdal / ESRI / NULL
Request Tracker grass-bugs at intevation.de
Thu Feb 14 09:42:08 EST 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=919
Hi Frank,
(cc Request Tracker <grass-bugs at intevation.de>)
while importing a DTM stored in an ESRI coverage I
found a NULL problem:
gdalinfo grid25x25
Driver: AIG/Arc/Info Binary Grid
Size is 8230, 9142
Coordinate System is '
Origin = (1617349.355468,5177716.393938)
Pixel Size = (25.000000,-25.000000)
Corner Coordinates:
Upper Left  ( 1617349.355, 5177716.394)
Lower Left  ( 1617349.355, 4949166.394)
Upper Right ( 1823099.355, 5177716.394)
Lower Right ( 1823099.355, 4949166.394)
Center      ( 1720224.355, 5063441.394)
Band 1 Block=32x32 Type=Float32, ColorInterp=Undefined
  Min=-235.000/1, Max=3338.541/1
  NoData Value=65536
r.in.gdal -eo grid25x25 out=dtm25.veneto
r.info dtm25.veneto
  Range of data:    min =  -340282346638528859811704183484516925440.000000
It seems that the ESRI NULL is misinterpreted somewhere.
Min=-235.000/1, Max=3338.541/1 are correct, it's in the Alps.
Perhaps you can look into this?
Thanks in advance,
 Markus
--- Headers Follow ---
>From neteler at itc.it  Thu Feb 14 15:42:07 2002
Return-Path: <neteler at itc.it>
Delivered-To: grass-bugs at lists.intevation.de
Received: from mail.intevation.de (aktaia [212.95.126.10])
	by lists.intevation.de (Postfix) with ESMTP id BEA2E13949
	for <grass-bugs at lists.intevation.de>; Thu, 14 Feb 2002 15:42:06 +0100 (CET)
Received: from camelot.itc.it (camelot.itc.it [195.223.171.5])
	by mail.intevation.de (Postfix) with ESMTP id A805C1B6BB
	for <grass-bugs at intevation.de>; Thu, 14 Feb 2002 15:42:05 +0100 (CET)
Received: from artemide.itc.it (artemide [10.0.10.10])
	by camelot.itc.it (8.11.3/8.11.3) with ESMTP id g1EEfwr18051;
	Thu, 14 Feb 2002 15:41:58 +0100 (MET)
Received: from thuille.itc.it. (thuille [10.40.0.110])
	by artemide.itc.it (8.11.3/8.11.3) with ESMTP id g1EEfvF01094;
	Thu, 14 Feb 2002 15:41:57 +0100 (MET)
Received: (from neteler at localhost)
	by thuille.itc.it. (8.11.6/8.11.2) id g1EEfvS31651;
Date: Thu, 14 Feb 2002 15:41:56 +0100
To: Frank Warmerdam <warmerdam at pobox.com>
Cc: Request Tracker <grass-bugs at intevation.de>
Subject: r.in.gdal / ESRI / NULL
Message-ID: <20020214154156.V29041 at itc.it>
Mime-Version: 1.0
Content-Type: text/plain; charset=us-ascii
Content-Disposition: inline
User-Agent: Mutt/1.2.5.1i
X-Spam-Status: No, hits=0 required=5 tests=
-------------------------------------------- Managed by Request Tracker
