[GRASS5] comment in ps.map
Roger Miller rgrmill at rt66.com
Thu Feb 14 15:06:55 EST 2002
On Thu, 14 Feb 2002, zhang ji wrote:
> Hi all,
> When I use the ps.map, I found it can only import one
> comment file. For example(from one ps.map input file):
> comments file1
> where 1,1
> end
> comments file2
> where 2,2
> end
I tried this example and didn't see the problem you described.  I was
running grass 5.0.0pre2 in Linux on an intel x86 machine.  Could the
problem be somewhere else?
Roger Miller
