[GRASS5] Re: Grass GUI
Radim Blazek radim.blazek at wo.cz
Mon Feb 18 18:49:30 EST 2002
On Monday 18 February 2002 12:20, M Lennert wrote:
> - d.area is being replaced by d.vect.area (or whatever we decide for the
> d.vect.* modules), so the script needs to be adapted to that
Tell me which commands and which options to use for vector lines and
vector areas and I'll do that. It is quite easy you can experiment:
search d.dm for d.vect and replace it  by command you want.
I am bit lost in all that d.vect.* modules :)=
> - I have a problem with the RGB color palette: when trying to create a
> customized color, it is displayed as 'grey'.
I'm not sure what you mean, legend? I found that legend doesn't work because
d.leg.thin was renamed to d.legend. Am I right?
> - Would it be possible to write any messages from d.dm (and the modules it
> calls) into a tk-window instead of the main Grass terminal ? That way one
> could already use this terminal while waiting for the commands to finish.
As I said, I do not continue in d.dm/g50 development, I can recomend
xterm -e d.dm  &
You must be careful with simultaneous commands - d.dm changes WIND.
Radim
Praga, Bohemia
