[GRASS5] v.in.shape missing some polygons
Gualter Barbas Baptista gualter at netcabo.pt
Sun Feb 24 19:46:36 EST 2002
When I import shapefiles using v.in.shape almost everything goes ok,
except for some polygons, that show up the lines, but have no values,
which means that when I convert the vector file to raster there is
nothing. I tried changing the colinearity tolerance and the snap
distance, but the result is the same.
I tried exporting one of these images back as a E00 and the polygons
that didn't show up had a value of zero. I changed manually the values
to 1 and re-exported to shapefile, imported in GRASS, etc. and I got the
same result.
Is this some known bug or am I doing something wrong?
Thanks,
Gualter
