[GRASS5] head/release differences details
Glynn Clements glynn.clements at virgin.net
Wed Feb 27 09:48:05 EST 2002
These are the details of the 19 files which genuinely differ between
the head and the release branch.
1.	src.garden/grass.postgresql/g.select.pg/Gmakefile
	src.garden/grass.postgresql/g.select.pg/getdbname.c
	src.garden/grass.postgresql/g.select.pg/listdb.c
	src.garden/grass.postgresql/g.select.pg/main.c
	src.garden/grass.postgresql/g.table.pg/Gmakefile
	src.garden/grass.postgresql/g.table.pg/infxTable.c
	src.garden/grass.postgresql/g.table.pg/main.c
These are due to Alex' i18n changes.
2.	src/CMD/head/head.in
Addition of INST_DIR, apparently due to 1 above.
3.	src/CMD/lists/GRASS
Removal of d.area, addition of d.vect.area, d.vect.line.
4.	src/include/gis.h
Change type of "checker" field in definition of "struct Option":
-    int (*checker)();               /* Routine to check answer or NULL  */
+    int (*checker)(const char *);   /* Routine to check answer or NULL:
+                                     * > 0 --> error, 0 == OK
5.	src/include/gisdefs.h
	src/libes/gis/plot.c
Addition of G_plot_area()
6.	src/tcltkgrass/main/menu.tcl
Remove menu entry for d.area, add entries for d.vect.area, d.vect.line
Disable (inactive) "Display USGS DLG-3 files" menu entry.
7.	src/display/d.dm/d.dm
	src/display/d.vect/cmd/local_proto.h
	src/display/d.vect/cmd/main.c
	src/display/d.vect/cmd/plotCat.c
	src/mapdev/v.alabel/main.c
	src/mapdev/v.llabel/main.c
Various changes, suggesting work in progress.
Glynn Clements <glynn.clements at virgin.net>
