[GRASS5] r.neighbors: works with reclass maps?
Markus Neteler neteler at itc.it
Fri Jan 4 12:34:45 EST 2002
On Wed, Jan 02, 2002 at 09:35:28PM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > while using r.neighbors on reclassed maps (from r.reclass)
> > I got some strange results.
> Are you referring to the result map being almost entirely null?
> E.g.
> 	r.neighbors -z input=soils.Kfactor output=foo method=minimum size=5
> produces a map which is null except for the very left-hand edge, while
> 	r.mapcalc 'sk=soils.Kfactor'
> 	r.neighbors -z input=sk output=foo method=minimum size=5
> seems to work OK.
> > Is it possible that we have
> > to added a test into r.neighbors? Or is it a local problem
> > only?
> The bug is in libgis.
> The call to G_get_d_raster_row() in readcell.c returns only NaN for
> the original (reclass) "soils.Kfactor" map, but sensible values for
> the (non-reclass) "sk" map.
> I've tracked this down to the double use of a static buffer
> (G__.mask_buf) in G_get_raster_row().
> For reclass maps, G_get_raster_row() uses G__.mask_buf as a temporary
> buffer. It calls G_get_c_raster_row(G__.mask_buf), which in turn calls
> embed_nulls(G__.mask_buf), which calls G_get_null_value_row().
> However, G_get_null_value_row uses G__.mask_buf itself (via the macro
> MASK_BUF) to hold the mask row.
> Summary: static "work buffers" are a bad idea.
> Unfortunately, some systems don't support alloca(), and some of those
> which do don't make it straightforward to use. autoconf has a
> solution, but it's messy. And using malloc()/free() for short-lived
> buffers could significantly harm performance.
> For the time being, I guess that we'll have to just add another static
> work buffer for the purpose of reclass maps. However, I'm not yet sure
> of the mechanism used for allocating and reallocating such buffers.
Glynn,
thanks for looking into this! Do you see a chance to work
around? I have seen some malloc tests in other "configures"
such as GDAL etc. Perhaps they have a functional autoconf
implementation?
Markus
