Programming language C vs c++ (was: [GRASS5] Want GNU libavl ?)
David D Gray ddgray at armadce.demon.co.uk
Tue Jan 22 18:23:40 EST 2002
Bernhard Reiter wrote:
> On Mon, Jan 21, 2002 at 10:39:07PM +0000, David D Gray wrote:
>>But the truth is that few people _if
>>any_ today in engineering, research, academia use C as the development
>>language. It is almost universally C++ that is used.
> I do not agree with the statement.
> And even if I did I call it a mistake to bet on C++.
> We can agree upon that this mistake is made by a large group of
> people, though. There is no reason to repeat it.
Well I'm afraid I must repeat it again, because it is my regular
experience. Though I do agree it is a mistake to bet on C++, and I think
its wide adoption is to do with the political ramifications of the
commercial software world and its central role for many years in Visual
Studio. It's popular because it's just what's used in 'Software
Engineering' circles. Of course among many engineering disciplines, the
coding requirements are very low-level - on a par with kernel hacking,
and here you will find C ; also in RT systems.
> Without going into the details I do not consider C++ a nice
> programming language. There are also general doubts regarding
> the object-orientated approach in computer science now.
> It concerns databases and programming languages.
No disagreement here on the first point,  but i find that
object-oriented features become a natural solution as you move towards
more complex data structures. I also find it a real pain to spend so
much of my development time taken up with trivial memory bugs, that
really should be able to be handled by the language - but that takes us
in a different direction from C++.
> For a pointer to skepticsm regarding C++ see one of the
> better "language discussions":
> 	http://www.advogato.org/article/207.html
Well, these things have been repeated often, and are just brought
together here in one place. They are perfectly true, but to repeat I
don't advocate major adoption of C++ code in the GRASS core, we should
just consider accomodating it now in the case of libraries that we would
like to use and where it is found not to have major portability or
stability problems.
Regards
David
