[GRASS5] Projection transform
Markus Neteler neteler at itc.it
Wed Jan 23 05:16:20 EST 2002
On Wed, Jan 23, 2002 at 09:44:20AM +0000, Glynn Clements wrote:
> Markus Neteler wrote:
> > ...just an addition: There is also m.proj2 which is the command line
> > version of m.proj.
> Is there any significant reason why these aren't cmd/inter versions of
> a single program?
> Certainly, they have a lot of common code (geo_func.c and get_deg.c
> are identical, process.c differs only in whitespace, get_stp.c differs
> only due to debugging statements).
I assume that the m.proj2 is intended to replace the m.proj
(hi Bob). A cleanup is needed, such clones are not desired.
Markus
