[GRASS5] configure goof?
David D Gray ddgray at armadce.demon.co.uk
Sat Jan 26 22:41:41 EST 2002
Glynn Clements wrote:
> David D Gray wrote:
>>This is picking up Tcl/Tk for TkStep, an old version I still require in
>>/usr/local/*. I tried to configure as you can see that it would pick up
>>the correct 8.3 libs in /usr/* (I actually have 6 Tcl versions scattered
>>about). Then I noticed that this only appends the include and lib
>>directories specified. If that is the case, it seems wrong to me: the
>>`--with-tcl-incudes' should specify where to look, or at least prepend
>>the specified directory. I notice the tiff libs are searched the same
>>way, perhaps all search paths are specified this way. If so, can they
>>all be changed?
> I've fixed the configure checks.
It's still picking up the headers in the /usr/local/include directory.
However if I disable these temporarily, the correct headers in
/usr/include are found.
David
