[GRASS5] New GIS & GRASS5 user with many questions...
Markus Neteler neteler at itc.it
Wed Jan 30 07:50:21 EST 2002
Hi Samizdatt,
the ./testgrass.sh is only intented to test GRASS on a system level.
You may want to use
Spearfish sample data,
have a look at:
http://grass.itc.it/data.html
GRASS 5.x: SPEARFISH dataset (9.6MB size)
+ " SPEARFISH dataset related documents: "
Enjoy,
 Markus Neteler
On Tue, Jan 29, 2002 at 04:24:22PM -0700, Samizdatt wrote:
> GRASS5 is compiled, and appears to run, but are there any sample data sets I can use to test and familiarize myself with GRASS5?
> **********  Output from testgrass.sh **********
> org:/install/grass5.0.0pre3 # ./testgrass.sh
> testing in UTM projection environment:
> projection: 1 (UTM)
> zone:       13
> datum:      ** unknown (default: WGS84) **
> ellipsoid:  ** unknown (default: WGS84) **
> north:      4928000
> south:      4914000
> west:       590000
> east:       609000
> nsres:      50
> ewres:      50
> rows:       280
> cols:       380
> Test the -129 r.mapcalc bug:
> EXECUTING testmap = ...  100%
> CREATING SUPPORT FILES FOR testmap
> range: -129 -129
> r.mapcalc bug test o.k.
> Tests finished.
> My goal is to display county level data sets, currently in FIPS codes, onto a map of the US, and individual states. I'd like to deliver the images via webserver to clients using a browser. As I perused the programming manual, I noticed that there are limitations to html's ability to render clickable points, which I can work through later, but I'd like to know if I'm on the right track in using GIS & GRASS5. Also, any links, hints or info anyone can provide to additional information would be greatly appreciated.
> Thanks!
> grass5 mailing list
> grass5 at grass.itc.it
> http://grass.itc.it/mailman/listinfo/grass5
