[GRASS5] Re: intersect sites with polygons?
Radim Blazek blazek at itc.it
Fri Jul 5 09:18:54 EDT 2002
On Friday 05 July 2002 12:39 pm, Christoph Simon wrote:
> The classic SQL example for an aggregate functin is:
> 	select max (val) from tab where ...;
> this will return just one row, so it's not going to be typical as an
> attribute.
Select object with category with max value? Not frequent, but say that wee
want see tha last added feature. Should be possible in this way:
where cat = (select max (cat) from tbl);
> OTOH, SQL generally and Postgres in particular allows to
> write SQL and C-language based functions, which can do more or less
> everything: Someone might have a map associated with one or more
> tables and one column for each set of climate data measured. This is
> the point, where she could experiment with different algorithms to
> predict future values, compare it to already known ones and compute an
> index of quality of prediction which would be displayed in the map.
Example of SQL statement for this?
> One thing I use pretty frequently, which is not an aggregate function
> but which also requires access to the first part are more or less
> simple arithmetic operations;
> 	select inches * 25.4 AS milims from...
Yes, but it does not return list of categories, i guess?
Radim
