[GRASS5] GLib?
Bernhard Reiter bernhard at intevation.de
Thu Jun 6 11:35:51 EDT 2002
On Thu, Jun 06, 2002 at 04:51:29PM +0200, Radim Blazek wrote:
> (Was "Want GNU libavl ?" 6 monts ago
> http://grass.itc.it/pipermail/grass5/2002-January/001704.html )
> > > > The latest GLib is probably the closest I can think of.  It has hashes,
> > > > trees, sets, etc...  The reason I went with libavl, is it is purportedly
> > > > better optimised for the balanced trees, and it's simple to include the
> > > > files you need (two in my case).
> > > I see... but GLib is at the core of the GNOME programming environment...
> > > is it possible to extract only the more general part without having to
> > > carry also GNOME dependacies?
> > GLIB can be used alone.  It is why they made it a separate lib.
> > Robert Lagacé, professeur
> Can we start to use GLib in grass51?
I'm sceptical.
Why this library? Why a library at all.
Why not wait until grass 5.3?
Name: not available
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020606/8311a9aa/attachment.bin
