[GRASS5] configuration/build failure on solaris 8, curses and get/putwc
Hal Mueller hal at mobilegeographics.com
Wed Jun 19 15:52:21 EDT 2002
Thanks for the help, everyone.  Redefining CPPFLAGS to ignore
warnings did the trick.
I don't know whether "fixincludes" was run; I am using a canned
Solaris GCC package from sunfreeware.com, which I obtained sometime
during the Clinton administration.  It's gcc 2.8, woefully out of
date I know.
Builds of both pre4 and the current CVS tree went fine, at least
until I filled up my /opt partition.  I've rearranged space and am
rebuilding, but I don't see any reason things won't work.  I'll post
a "success" message for the dev tree when I get one, and will also be
setting up to do a nightly CVS update/rebuild on the dev tree.
H
