[GRASS5] v.in.mif currently broken ?
Moritz Lennert lennert.moritz at edpnet.be
Thu Jun 20 19:30:47 EDT 2002
Just for info: it's still enabled in the (current for the next few days ;-) pre4 releasei, at least when built from source.
Moritz
On Thu, Jun 20, 2002 at 09:47:24PM +0100, David D Gray wrote:
> Moritz,
> The current code is not usable at all. It is disabled from the default
> build so will not appear in binary releases. A module based on existing
> modules like v.in.shape is in development, but key parts still have to
> be coded, tested etc, so it is not ready for the stable release, which
> is now effectively frozen.
> v.in.shape is now hopefully fully functional and stable, so one way is
> to use third party utilities like Mitab and OGR to convert various other
> kinds to shapefiles, and import that way.
> David
> Moritz Lennert wrote:
> > Hi all,
> > Am I correct in understanding that v.in.mif is currently broken ?
> > If yes, what are the alternatives ?
> > Moritz
> > grass5 mailing list
> > grass5 at grass.itc.it
> > http://grass.itc.it/mailman/listinfo/grass5
