[GRASS5] [bug #1124] (grass) v.in.sdts segmentation fault on illegal tag
Eric G. Miller egm2 at jps.net
Fri Jun 21 07:11:43 EDT 2002
On Wed, Jun 19, 2002 at 08:29:44PM +0200, Request Tracker wrote:
> this bug's URL: http://intevation.de/rt/webrt?serial_num=1124
> Subject: v.in.sdts segmentation fault on illegal tag
> I updated the Grass5pre4 source from CVS on June 18, 2002.  I am running
> SuSE 8.0 on PII 350 mHz system with 512 mb ram and a 20 gb hard disk.  Upon
> trying to read an SDTS data file for Caples Lake, Cailfornia that should
> contain vector lines for contour data, I get an error.
  Does it?
> v.in.sdts -i yields the following.  v.in.sdts does not process the LE module
> as part of this process.
> v.in.sdts output -----------------
> Processing CATD module
> Processing STAT module
> Processing IDEN module
> Processing XREF module
> Processing IREF module
>          INFORMATION ABOUT THE SDTS DATA SET
> Identification module:  9760IDEN.DDF
> Standard identification:           SPATIAL DATA TRANSFER STANDARD
> Standard version:                  1998 JUNE 9
> Standard documentation reference:  ANSI NCITS 320-1998
> Profile identification:            SRPE: SDTS RASTER PROFILE and EXTENSIONS
				     This is not the vector profile....
> Profile documentation reference:   Federal Geographic Data Committee
> FGDC-STD-002.5
> Profile version:                   1998
> Title:                             CAPLES LAKE, CA-24000
> Data ID:                           LAT::   38 37 30.0000 N LONG:: -120  0
> 0.0000 W SCALE:: 24000
> Data structure:                    DEM
				     And, it's an elevation model....
Use r.in.gdal to import SDTS DEM's....
Eric G. Miller <egm2 at jps.net>
