[GRASS5] Fwd: fink'ing grass on darwin/osx - $env(TCLTKGRASSBASE) error -solved
andy agena andya at mac.com
Thu Jun 27 13:20:55 EDT 2002
hello again:
i did some more poking around and found the answer.  i simply added
'TCLTKGRASSBASE: /sw/grass5/tcltkgrass' to my .grassrc5 and it did the
take care,
Begin forwarded message:
> From: andy agena <andya at mac.com>
> Date: Thu Jun 27, 2002  09:38:46 AM US/Central
> To: GRASS5 <grass5 at grass.itc.it>
> Subject: fink'ing grass on darwin/osx - $env(TCLTKGRASSBASE) error
> hello all:
> i decided to try my hand at compiling the grass5pre5 source within the
> fink structure (a great tool for os x / darwin users to get unix
> packages; see <http://fink.sourceforge.net/>).  since fink has its own
> directory (/sw) i decided to put grass5 there (/sw/grass5) with the
> following:
> sudo ./configure --prefix=/sw --with-includes=/sw/include --with-
> libs=/sw/lib --with-tiff-includes=/sw/include --with-tiff-libs=/sw/lib
> --with-tcltk-includes=/sw/include --with-tcltk-libs=/sw/lib/tcl8.3
> --with-gd-includes=/sw/include --with-opengl-
> includes=/usr/X11R6/include --with-fftw-includes=/sw/include
> --without-odbc  --without-postgres
> aside from the compilation errors below, this worked.  i didn't include
> odbc or postgres, as they're not (yet) in the stable tree of fink; i'll
> add dbm, motif, freetype, and readline next ./configure, as i didn't
> have them fink'ed yet.  g77 is also available via fink.  as you can
> see, i've pointed configure to the fink includes and libs, tcltk
> included.
> so my configuration is like this:
> GRASS is now configured for powerpc-apple-darwin5.5
>   Source directory:          /sw/src/grass5.0.0pre5
>   Build directory:           /sw/src/grass5.0.0pre5
>   Installation directory:    /sw/grass5
>   C compiler:                gcc -g -O2
>   FORTRAN compiler:
>   NVIZ:                       yes
>   X11 support:                yes
>   DBM support:                no
>   JPEG support:               yes
>   TIFF support:               yes
>   PNG support:                yes
>   GD support:                 yes
>   Tcl/Tk support:             yes
>   PostgreSQL support:         no
>   OpenGL(R) support:          yes
>   ODBC support:               no
>   FFTW support:               yes
>   BLAS support:               no
>   LAPACK support:             no
>   Motif support:              no
>   FreeType support:           no
>   GLw support:                no
>   NLS support:                no
>   Readline support:           no
> only a couple errors:
> GRASS GIS compilation log
> Start of compilation: Thu Jun 27 08:12:57 CDT 2002
> Errors:
> Compilation error in module: src/libes/vect32/georef (ignored)
> Compilation error in module: src/raster/r.in.gdal (ignored)
> Compilation error in module: src/raster/r.sun (ignored)
> Compilation error in module: src.contrib/GMSL/g3d/src3d/sites/s.vol.rst
> (ignored)
> End of compilation:   Thu Jun 27 08:50:47 CDT 2002
> DONE generating GRASS GIS binary code
> however, when i try to fire up tcltkgrass&, i get an error that
> $env(TCLTKGRASSBASE) isn't set, so i check my ~/.grassrc5 and its not
> there.  what is this env variable looking for?  can i just point it to
> the appropriate place via my ~/.grassrc5 file?  i already tried the
> old ' source /etc/csh.cshrc /etc/csh.login ' and it didn't work.
> thanks in advance for any suggestions.
> take care,
> andy a.
> p.s. since i'm a digest lister, please write directly or cc me.
