[GRASS5] Re: Grass clones
Glynn Clements glynn.clements at virgin.net
Fri Mar 15 02:53:41 EST 2002
Markus Neteler wrote:
> I do not re-sent the new GRASS clones analysis here due to bandwidth
> limitations, but I have put this preliminary analysis online:
>  http://mpa.itc.it/markus/tmp/grass.cln
>  (550k, ASCII)
I've attached a couple of scripts for processing the data. One is an
awk script to add ID numbers and convert it to CSV. The other is an
SQL script which performs some simple computations (e.g. number of
code lines, number of distinct files).
Glynn Clements <glynn.clements at virgin.net>
Type: application/octet-stream
Desc: grass-clone.awk
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020315/82e5a2dd/grass-clone.obj
Desc: grass-clone.sql
Url : http://lists.osgeo.org/pipermail/grass-dev/attachments/20020315/82e5a2dd/grass-clone-0001.obj
