[GRASS5] [bug #970] (grass) nviz cutting planes freeze
Glynn Clements glynn.clements at virgin.net
Sat Mar 16 00:25:07 EST 2002
Request Tracker wrote:
> Subject: nviz cutting planes freeze
> nviz freezes when cutting plane is on and an additional surface is
> added (for example there are two surfaces and one cutting plane and I
> do New surface, add a constant, it creates it and then nviz freezes
> all its windows - graphical and all menus)
> The fix may be complicated, because there is obviously a problem to
> apply the cutting plane to newly created surface. Quick fix may be
> just to give a message to user that new surface cannot be added when
> cutting planes are on.
I can't reproduce the problem. Can you provide a specific test case?
Also, are you using software OpenGL, or a hardware-specific version?
(what does "glxinfo" say?)
Glynn Clements <glynn.clements at virgin.net>
