[GRASS5] The status of 5.0
Roger Miller rgrmill at rt66.com
Sun Mar 24 11:23:11 EST 2002
On Friday 22 March 2002 16:33, Helena wrote:
> Vector support is the weekest and should be addressed by GRASS5.1 -
> it should be made clear for GRASS5.0 that vector support is limited and
> encourage
I think that it's fairly well understood that GRASS provides only weak vector
support, but there is a difference between having "weak" support and
packaging modules that don't work or don't work right.
I guess we could argue about what is and isn't release critical.  From my
point of view, any known problem that prevents any packaged module from
operating or operating as it is documented to operate should be considered
release-critical.
Of the problems I pointed out at the beginning of this thread I think that at
least three have not been addressed:
1)  v.make.subj dies on a segmentation fault.
2)  v.merge is unusable because of 1)
3)  v.out.shape does not export lines.
Roger Miller
