[GRASS5] [bug #1033] (grass) motif and configure
Markus Neteler
neteler at itc.it
Thu May 2 03:03:25 EDT 2002
On Tue, Apr 30, 2002 at 06:59:34PM +0100, Glynn Clements wrote:
> Markus Neteler wrote:
> > > 3. Or are we discussing the OpenGL widget library (lib*GLw*)? Which is
> > > a separate problem to either OpenGL or Motif.
> > Yes, this problem remains (GLwCreateMDrawingArea is needed for compilation):
> > configure ... --with-glw
> > checking whether to use GLw... yes
> > checking for location of GLw includes...
> > checking for GL/GLwMDrawA.h... yes
> > checking for location of GLw library...
> > checking for GLwCreateMDrawingArea in -lGLw... no
> > checking for GLwCreateM1DrawingArea in -lGLw... no
> > checking for GLwCreateM2DrawingArea in -lGLw... no
> > checking for GLwCreateMDrawingArea in -lGLwM... no
> > checking for GLwCreateM1DrawingArea in -lGLwM... no
> > checking for GLwCreateM2DrawingArea in -lGLwM... no
> > configure: error: *** Unable to locate GLwM library.
> > On my Redhat box is
> > locate GLw
> [snip]
> > /usr/lib/libMesaGLw.a
> I'll check for that as well, but does that library include the Motif
> widget (use "nm /usr/lib/libMesaGLw.a")? If not, you will need
> libMesaGLwM.a.
No, it is not included in this Redhat 7.1:
nm /usr/lib/lib*GL*.a |grep GLwCreateM
-> nothing
So I have to compile libMesaGLwM.a (aarg).
Markus
