[GRASS5] [bug #1035] (grass) p.map.new memory access failure
Request Tracker grass-bugs at intevation.de
Thu May 2 07:30:02 EDT 2002
this bug's URL: http://intevation.de/rt/webrt?serial_num=1035
Subject: p.map.new memory access failure
Platform: GNU/Linux/i386
grass obtained from: Trento Italy site
grass binary for platform: Compiled from Sources
GRASS Version: 5.0pre3
p.map.new suffers a memory access failure while gathering map
statistics for a floating point raster:
GRASS:~ > p.map.new  test.pmap
Gathering map stats ...Speicherzugriffsfehler
With an integer raster p.map.new fails slightly later:
Gathering map stats ... 100%
>>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>> >>>>> >>>>> >>> >>>>> >>>>> >>> rows 597  cols 597
PAINT: panel 1 (of 1)
PAINT: reading vector file <einz_ges_mfd.i5 in buckow> ...
Below my test.pmap file is listed.
Henning
test.pmap:
#raster streampower.sheet.mfd_2001i
raster erodepo.sheet.mfd_1342
vect einz_ges_mfd.i5
  color black
  width 1
end
scale 1:2500
grid 100
 pattern tick 10 10
# masked data
 color black
 numbers 1
 numbersize 5
end
barscale 5438170 5827839
 unit m
 length 100
 interval 50
 style tick
 width 2
 color black
 textsize 6
 background white
 border black
end
legend 5438165 582710
#legend 5438300 582820
 height 180
 width 100
 vlen 20
# xspace 5
# yspace 5
 textcolor black
 textsize 6
 textwidth 1
 background white
 border black
 beginvect
 vectname einz_ges_mfd.i5
 end
 beginrast
 ramp value horizontal
 end
end
-------------------------------------------- Managed by Request Tracker
